View the OSPF default cost information to ensure accuracy.
View the OSPF cost information on the switch:
Switch:1#show ip ospf default-cost vrf 3 ========================================================================================== OSPF Default Metric - VRF 3 ========================================================================================== 10MbpsPortDefaultMetric: 100 100MbpsPortDefaultMetric: 10 1000MbpsPortDefaultMetric: 1 10000MbpsPortDefaultMetric: 1 25000MbpsPortDefaultMetric: 1 40000MbpsPortDefaultMetric: 1 100000MbpsPortDefaultMetric: 1
Variable definitions
The following table defines parameters for the show ip ospf default-cost command.
Variable |
Value |
vrf WORD<1-16> |
Specifies a VRF by name. |
vrfids WORD<0-512> |
Specifies a range of VRF IDs. |
